Posted by mkirsch on May 04, 2012 at 05:48:55 from (64.80.110.75):
In Reply to: 189 two-way plow posted by Anthony06070 on May 03, 2012 at 18:04:39:
There is a bar that connects to the right Touch Control arm and bolts to the reversed drawbar. You use the right-hand control to raise and lower the reversed drawbar to control depth.
The correct bar is adjustable. With the touch control arm all the way back, the front edge of the drawbar should be about 7-8" off the ground.
When in the furrow at maximum depth, the drawbar should be 1-2" off the ground.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
