Re: Farmall Super A clutch won't disengage
Posted by Barstart on May 04, 2012 at 09:27:29 from (158.222.42.59):
In Reply to: Farmall Super A clutch won't disengage posted by Barstart on May 03, 2012 at 16:35:39:
I found out what was wrong! I put the vibration damper plate together wrong at the transmission. It lengthened the drive shaft by about an inch and that was enough to put the shaft in contact with the engine full time.
