"If you want to eliminate any confusion on the wires just connect all four of the wires together at the voltage regulator and the connect both of them to the #1 terminal at the alternator."
Whoa Qwen, connecting all four regulator plug wires together is bad idea of the year. #3 regulator plug wire is direct from the battery, hot all the time. Connecting the #3 wire to the other 3 would keep the alternator field energized all the time, killing the battery in a few hours, also would disable the alt light circuit and backfeed power to anything on the ignition circuit.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
