Re: Starter drives,Older,spring style or rubber cushioned...
Posted by Janicholson on May 04, 2012 at 18:20:41 from (96.24.99.126):
In Reply to: Starter drives,Older,spring style or rubber cushioned new? posted by Mike1972chev on May 04, 2012 at 17:30:00:
There are 4 distinct advantages to the new drive in my opinion. All starter energy was directed through the helical spring of the old drive. None is driven through a metalic spring on the new.
The old drives often wore out internally and jamb into the gear teeth locking the starter, and engine. The new drives have no reputation to do so, they seem to cure and work well on pretty bad ring gears. They also have a cushon internally reducing the shock losding on teeth (both ring and pinion).
The drive bolts holding the drive spring in the old style are also prone to shear, or loosen.
There are none on the new style.
The old style has been in service for 4o or more years in some cases, and can"t be faulted. Many other starters fail dramatically more often. Jim
