Posted by Janicholson on May 04, 2012 at 18:27:18 from (96.24.99.126):
In Reply to: farmall h Beats me posted by mj56 on May 04, 2012 at 17:21:38:
If the hole in question is in the side of the hydraulic reservoir sump, and is thumb sized, there will be one on the opposite side as well. If that is the hole, it is for attachments (usually with hydraulic systems. It has a slot ata an angle (like a starting crank hole) used to allow the insertion of a pivoting rod with a cross pin in the end. The cross pin retained the rod in the hole. Different mounted implements used the pivot, usually from both sides. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
