Re: farmall h Beats me
Posted by glennster on May 04, 2012 at 18:45:41 from (99.90.9.153):
In Reply to: farmall h Beats me posted by mj56 on May 04, 2012 at 17:21:38:
i think wayne has it. if the hole is on the bottom area of the trumpet of the bell housing, it is the lube point for the pilot bearing. if you look at the crankshaft pulley, there will be a double st of timing marks close together, then about half way around the pulley, you should see a single mark. if you line up the single mark with the timing pointer, then look in the hole under the tractor, you should see the grease zerk.
