Re: Farmall H air cleaner question
Posted by CoopertownBob on May 04, 2012 at 22:17:58 from (74.51.5.80):
In Reply to: Farmall H air cleaner question posted by Jim Becker on May 04, 2012 at 19:03:09:
Dennis has it mostly correct. There should be a copper pipe connected from it to the port on the back of the head. It serves to pull a very slight vacuum on the crankcase, which helps to cut down on oil consumption among other things.
