Re: farmall h Beats me
Posted by CoopertownBob on May 04, 2012 at 22:18:29 from (74.51.5.80):
In Reply to: farmall h Beats me posted by Jim Becker on May 04, 2012 at 17:21:38:
On an H Farmall you can lube both, the pilot is done just like Wayne explained.
The hole in question though sounds like it might be the one to lube the throw-out bearing through, since the OP did say it was directly under the pump.
