The new rubber tipped needles need to have a set put in the in to work well from the get go. Over time they will set them self's but you can do it and that helps a good bit. What you do is drop the needle in the seat then tap on them a couple time. Pull it back out and look at the end and you should see a little ring formed in the tip if you see that then it has been set to fit. Learned that from an old carb guy who is long since gone. Also be sure to use the spring clip on them or they will stick closed and then you have the opposite problem
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
