Re: farmall super a does not start charging until runs a ...
Posted by Janicholson on May 05, 2012 at 10:15:01 from (199.17.55.146):
In Reply to: farmall super a does not start charging until runs a while? posted by kelby on May 05, 2012 at 10:03:55:
Though this seems crude, start it cold, then (using a plastic Hammer)tap the brush end of the Generator. If it immediately starts charging, I believe a rebuild with new brushes is in order.
If no change, tap the regulator in the same way, Not hard, but kinda like you were starting a meeting with a gavel when everyone was already quiet. Again if it starts immediately. It is the regulator. If it were mine, I would take off the lid, and burnish the contacts with 320 grit paper, then clean the grit and shavings with electrical cleaner. then wipe the contacts with a folded dollar bill. Jim
