Re: Re: Re: Water Temperature Gauge
Posted by RAW on September 23, 2000 at 18:54:29 from (206.28.170.195):
In Reply to: Re: Re: Water Temperature Gauge posted by Larry on September 23, 2000 at 17:40:23:
Just were does the temp sensor munt on the Super C. I know that on the C without a water pump it mounted in the return tube from the bottom of radiator to the engine. Never came off cold unless the tractor ran low on water and overheated. One day I had it get so hot it burned the valve cover gasket. Dieseled for five minutes after shutting it down.(I was just 16 at the tme)
Post A Followup
: Re: Re: Re: Re: Water Temperature Gauge
