Dirty field control points in the regulator can cause the problem you are having. Cleaning them as Jim suggested will probably correct your problem.
Dirty contact points will cause a higher resistance between them. When the generator is first started up the voltage in the field windings will be very low, possibly less than one volt. You need good contacts to ensure that this low voltage is grounded. With a good ground the field coils will use the small amount of current generated to become electromagnets to add to the residual magnetism in the pole shoes. When that happens the voltage will quickly spike upwards until it is great enough for the regulator to start to control the maximum voltage.
The simple test is to ground the filed terminal on the generator once the engine is started. If that causes the generator to immediately start to work you know the problem will be dirty or loose contacts.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
