If you take the fast hitch off and pin the bail under the platform, your lowest clearance is at the front axle. The clearance is about 22 inches at that point. You can cultivate crops that are significantly taller than that if they will spring back into place (like corn). Your fast hitch height will range from 6 inches to 25 inches. Once you drop your rear cultivators, your clearance at the fast hitch will be less than that of the front axle. The fast hitch bail height is adjustable based on the height of the front lift. The lower the front cultivators, the lower the bail. The bail can be pinned under the seat for maximum clearance by switching a pin. The fast hitch itself comes off by pulling 3 pins.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
