If you take the fast hitch off and pin the bail under the platform, your lowest clearance is at the front axle. The clearance is about 22 inches at that point. You can cultivate crops that are significantly taller than that if they will spring back into place (like corn). Your fast hitch height will range from 6 inches to 25 inches. Once you drop your rear cultivators, your clearance at the fast hitch will be less than that of the front axle. The fast hitch bail height is adjustable based on the height of the front lift. The lower the front cultivators, the lower the bail. The bail can be pinned under the seat for maximum clearance by switching a pin. The fast hitch itself comes off by pulling 3 pins.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
