If it clears up in 10 min or so all is well, run it. Diesels run very cold unless worked for a living. It is not going to heatup until the plow is in the ground. Leave the cardboard off when doing that. The engines are pretty good if running OK repairs are seriously costly as the parts are made from "unobtanium" or "cost your first born" If you want to use it as a short run utility tractor Off on off on ten minutes at a time and the garden, it is not your best option, a gasser is much better for that. I own one of those gassers and it is just fine. The diesels are tough to start, even with a good manifold heater device (standard equipment, but not much help.) A whiff of starting fluid was always used on our neighbors 350UD even within 10 min of shutting it off. Jim
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
