Re: Calling all Farmall Offset Tractor Gurus
Posted by SouthernFarmall on May 05, 2012 at 20:02:01 from (184.3.102.98):
In Reply to: Re: Calling all Farmall Offset Tractor Gurus posted by CNKS on May 05, 2012 at 18:16:29:
I apologize. For whatever reason, I was thinking that you could run rear cultivators and keep the drawbar on, just like fast hitch tractors. I forgot the drawbar had to be removed. Gene and CNKS are correct.
SF
