The regulator you have requires only one wire to make it work. It also has provision for an additional wire to use the indicator light.
The B+ should be connected to the battery terminal on the alternator and the B- to the ground terminal. It should work without a wire on the light terminal. Like the one wire 10SI alternators it may take a high rpm to get it to start to charge. If it doesn't start to charge at high idle you can try putting battery voltage on the light terminal.
Single wire alternators depend on residual magnetism in the rotor to provide enough current to enable the field coil in the rotor to start to work. When they sit for a long time they can lose enough residual magnetism that you have actually have to polarize them to get them to start to work. Putting voltage on the light terminal will do that since it is connected to the original R terminal on the alternator.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
