Re: Calling all Farmall Offset Tractor Gurus
Posted by gene bender on May 06, 2012 at 05:00:50 from (67.55.226.143):
In Reply to: Calling all Farmall Offset Tractor Gurus posted by RTR on May 05, 2012 at 12:19:01:
Your rear tread can be moved at 4in spacing to get the width for your row width. You can do one or more rows depending on which cult you have as the veggie models were made for mulit row. Drawback would be height clearence for tall crops. I have two of them for the A. One could be used on the B and BN also. Finding the shank clamps is not easy some use the common round shanks and some used flat bar.
