Re: Rubber tipped float needles
Posted by rustyfarmall on May 06, 2012 at 05:07:06 from (67.55.162.174):
In Reply to: Rubber tipped float needles posted by Indiana Ken on May 05, 2012 at 19:02:38:
Immersing a float into BOILING water is a sure fire way to destroy that float. It will cause the air trapped inside that float to expand and basically rupture the float. Warm water is all you need. If you cannot comfortably put your fingers in it, it is TOO hot.
