International mod 240
Posted by Pete E. on May 06, 2012 at 05:43:16 from (69.136.132.99):
I have a international mod 240 with a steering problem it has a bucket on the front.when I bough the tractor it did not have power steering. went to a place in Ind.and bought the block and steering column the problem is the steering only works when you put a little persure on one of the controls.I pulled the block apart and checked the o-rings and for a stuck valve all seem fine put in all new o-rings any ideas Pete Thank You.
