Re: Farmall H M 150 Disc plow question
Posted by CNKS on May 06, 2012 at 07:39:32 from (216.144.104.128):
In Reply to: Farmall H M 150 Disc plow question posted by Richardmo on May 05, 2012 at 19:30:20:
I can't help you with the measurements because I haven't seen one in over 50 years. I will say that the bracket that takes most of the load is very heavy duty, and that I wouldn't recommend something like angle iron. The arms go straight down with braces angled back about 45 degrees. The plow pulls by a heavy round rod (not pipe) between the arms. I don't believe the actual dimensions are that critical. It pulls from a few inches above the ground, about drawbar height or somewhat lower. Salvage may be your only option. You need salvage yards mainly in S Texas and the south/southeast. The steering attachment is a bracket curved to the rear that bolts to the lower bolster in front of the attachment to the upper bolster. Your H should have those holes, our 47 H did.
