Re: suggestion on rebuild kit
Posted by El Toro on May 06, 2012 at 07:55:30 from (108.3.225.57):
In Reply to: suggestion on rebuild kit posted by MF165Farmer on May 06, 2012 at 01:13:01:
Have your crankshaft measured for wear at your local auto machine shop. They won't grind it undersize unless it needs it. It may need polishing. Buy your bearings from the machine shop. They also have sleeve kits here on this forum. Hal
