17 is about all those gens can produce after eating wheeties all morning. So two things to check (John hit the nail, more info is needed) Charging voltage with a good battery that is fully charged to begin the test should be 7.2 to 7.4 volts at 2/3 throttle or more. If in the 8 to 9 volt area, it is not being regulated correctly. The generator should not charge if the field terminal is disconnected. If it does, the field is internally shorted to ground, (a long bolt used to mount the regulator can short the field and not only make it put out, it can make the field draw much more current than normal, making more output than desired. Let us know. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
