Re: Cub stops when hot
Posted by Janicholson on May 06, 2012 at 09:54:28 from (67.72.98.45):
In Reply to: Re: Cub stops when hot posted by beargap on May 05, 2012 at 17:09:46:
That is it. Put a 12 volt coil for use with no external resistor if it has no resistor, Use a 12v coil for use with an external resistor if it has one. (usually an attachment near the coil with the coil connected to one side and the ignition switch the other. Jim
