Re: Farmall Super C won't crank
Posted by Don Mountain on May 06, 2012 at 14:12:30 from (184.5.194.195):
In Reply to: Farmall Super C won't crank posted by Don Mountain on May 06, 2012 at 13:24:43:
It has a new battery in it and the posts were all cleaned on both ends of the battery wires and everything is in good shape there. I have had this intermittent problem before. Its just like the switch isn't making. The lights are bright and don't dim when I try to start it. But I don't hear anything from the starter. So, how does the switch come off? I guess I better go look at it. Maybe its obvious. Do I need to take the starter off to work on the switch or does the switch come off the top of the starter?
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
