Re: Re: upping HP on a stock M?
Posted by Dick Davis on September 24, 2000 at 04:46:07 from (205.188.199.52):
In Reply to: Re: upping HP on a stock M? posted by Oldtractor on September 23, 2000 at 20:40:27:
Baling and plowing? Unless you are turning hundreds of acres with a 4 bottom or bigger plow or you want to pull one of those "makes a ton size bale" your M as built by IHC will handle the job fine. Now if you want to just screw around and have a bigger M than the guy down the road, thats fine and as good a reason as any to pour money into your old iron. Actually it's a better reason than most of us have! Go for it.
Post A Followup
: Re: Re: Re: upping HP on a stock M?
