Re: checking rear end oil
Posted by Red Mercury on May 06, 2012 at 20:36:47 from (204.112.23.236):
In Reply to: checking rear end oil posted by Lowell Gehring on May 06, 2012 at 18:43:06:
It may be the same as my 504 utility. The level plug for the transmission & rear end on my 504 is on the left side of the transmission housing. It is directly underneath/behind the left foot panel. It is a 1/2 inch pipe plug that is drilled & tapped for a 1/4 bolt (7/16 head). You unscrew the 1/4 inch bolt from the center of the pipe plug to check the oil level. I think the 504 & 606 utilities shared the same transmission. There is no dipstick on my 504. Hopefully someone else will reply and confirm.
