Re: b farmall fluid level check
Posted by gene bender on May 07, 2012 at 04:30:19 from (67.55.226.143):
In Reply to: b farmall fluid level check posted by RALPH1111 on May 06, 2012 at 23:55:37:
Thats the plug behind the brake rod for level in the tranny and the belt pulley getsits oil from the tranny. You can remove the fill plug and see if there is any there as the passage can get plugged. You dont need any lube in the belt pulley unless you are going to use it. By removing the fill plug and turning the drive over you will see if there is any there.
