The two bolts holding the starter to the bell housing. Unbolt them and wiggle the starter as the bendix mite be locked up on the ring gear. I would remove the starter and check all the teeth on the ring gear as you just mite have some bad worn teeth and the bendix drive will get locked up trying to turn the flywheel over also the teeth could be worn bad enough on the bendix putting a new bendix on the starter will not cure bad teeth on the flywheel but mite help.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
