Re: A Starter Puzzle
Posted by gene bender on May 07, 2012 at 05:06:49 from (67.55.226.143):
In Reply to: A Starter Puzzle posted by SuperABen on May 06, 2012 at 10:25:11:
Simple test with engine running check the voltage on the A terminal of the gen if it doesent read 6 pluss volts ground the field terminal on the gen. If that shows 6pluss volts on the A terminal the reg is bad. If there is no voltage on the A term the gen is bad. If you need a new regu;ator check the Delco Remy# on the genny to get the correct reg Your gen should be a Delco 1101355 or 1101423 but after all the yrs hard to tell what is there now and a trip to a genny shop is in order.
