Re: A Starter Puzzle
Posted by El Toro on May 07, 2012 at 05:37:07 from (108.3.225.57):
In Reply to: A Starter Puzzle posted by SuperABen on May 06, 2012 at 10:25:11:
Your kill switch has nothing to do with your engine not cranking. Use your hand crank to see if your engine is stuck. If you can't hand crank
the engine pull all the sparkplugs and try the hand crank. Could be water on top of the pistons as been mentioned. Hal
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
