Cub won,t fire on #4
Posted by Bill Bowles on May 07, 2012 at 07:34:50 from (173.166.167.77):
I have a 47 Cub that was running fine until head gasket blew. After new gasket , won,t fire on #4. Compression around 100 psi on all four cylinders, when plug laid on block shows good blue spark, starts instantly and runs on 3 cylinders. plug seems not as wet as it should be. Swiched plugs around, Disassembled and cleaned carb,seems like not drawing fuel to this cylinder, but good compression. any ideas?
