Re: Lift capacity of a belly pump?
Posted by Super-H-Mike on May 07, 2012 at 11:16:16 from (76.164.147.68):
In Reply to: Lift capacity of a belly pump? posted by BigTone on May 07, 2012 at 10:47:23:
I would think you should be able to lift 350lbs pretty easily. I have lifted some pretty heavy stuff with my tractors that have Lift-Alls. Most of what I lift is of unknown weight, but for refference, a big block Chevy with auto trans attached is around 700lbs, and I lifted that with no trouble at all.
