Re: Lift capacity of a belly pump?
Posted by wisbaker on May 07, 2012 at 12:03:18 from (207.118.179.78):
In Reply to: Lift capacity of a belly pump? posted by BigTone on May 07, 2012 at 10:47:23:
The lift cylinder diameter is the factor. Remember the hydraulic system is works because you get a mechanical advantage, the displacement in your pump will equal the displacement in the lift cylinder, the larger the lift cylinder the less movement you get for each cubic inch/centimeter, ounce or liter of fluid you pump, that's where your advantage (leverage) comes from.
