Re: Lift capacity of a belly pump?
Posted by Andrew Z on May 07, 2012 at 12:38:03 from (64.252.115.167):
In Reply to: Lift capacity of a belly pump? posted by BigTone on May 07, 2012 at 10:47:23:
pump pressure is 600ish for earrly to 800psi ish for the late ones. They can get over 1000psi if you mess with the spring.
dont forget: Force = pressure of the pump * area of the piston surface
Andrew
