Re: cast rear hubs for 766
Posted by mkirsch on May 07, 2012 at 12:18:39 from (64.80.110.75):
In Reply to: cast rear hubs for 766 posted by kennell on May 07, 2012 at 07:37:29:
Are you SURE it's the hub?
Installers are not always that careful when replacing the rims, and don't tighten the lugs evenly all the way around. That makes the tire wobble.
You should be able to take the wobble out by loosening, then re-torquing the lugs that hold the rim in place. Use a gauge block to judge whether the rim is running true.
