Re: Another H Wide Front Question...
Posted by Crazy Red Power in SE-WI on May 07, 2012 at 18:40:31 from (68.114.237.14):
In Reply to: Re: Another H Wide Front Question... posted by riverbend on May 07, 2012 at 18:13:11:
My sickle mower bolts to the drawbar & I have it mounted a bit right of center to keep the mower's inner shoe in line with the tractor's rear tire. I spread my wheels & axles as far apart as I can get them so I don't run down the cut hay before it gets to the conditioner. Unfortunately, I run out of drawbar holes before I run out of axle, so the right rear is in 5" - 6" from the end while the left is out to the end of the axle. If I have to keep everything centered, no prob. I'd just like to see if I'm able to offset the axle a bit without hurting anything.
Thanks,
Mike
