Re: cub 154 electric problem
Posted by Janicholson on May 07, 2012 at 20:16:52 from (67.72.98.45):
In Reply to: cub 154 electric problem posted by Steve alderman on May 07, 2012 at 17:53:05:
If there is an alternator installed, it could be feeding back through the ignition. It needs a diode in the wire going to the #1 spade terminal on the alt. The diode band end is to the alternator.(a guess at the problem) Jim
