Posted by Harvesterguy on May 07, 2012 at 20:28:40 from (98.252.40.29):
Gentlemen,
My 656 has developed a jump in the 3pt after spraying some rather rough ground with a 300 gal 3 pt sprayer. Now when I raise the hitch even with light loads it will come up to level, drop about 2" and then raise again. It pulses at the frequency of about once per second. The hitch seems to have the same lift capacity, though it"s tough to tell when its jumping. I"ve pulled the top cover and the pressure relief is not bypassing, and I do not see any bubbling/turbulence. The service manual says it may be the oring/seal on the cylinder, or the drop cushion valve and to determine the problem via inspection but doesn"t explain how to inspect. Any suggestions would be greatly appreciated.
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
