Re: Bolts for farmall h rear wheel weights
Posted by Dean Oson on May 07, 2012 at 20:56:04 from (98.196.66.64):
In Reply to: Bolts for farmall h rear wheel weights posted by TylerFarmallH on May 07, 2012 at 18:51:45:
Factory bolts are 3/4" x 4 3/4" square head for the 1st set. They
are a little shorter for the next sets.
I use 3/4" all threaded rod. Nuts on both sides of the wheel and a
3rd one on the end to hold the weights on.
