Re: cub 154 electric problem
Posted by Janicholson on May 07, 2012 at 21:08:41 from (67.72.98.45):
In Reply to: Re: cub 154 electric problem posted by Steve alderman on May 07, 2012 at 20:57:11:
Incorrectly wired, or stuck starter relay internal connection. ignition bypass could do it. Pull off the belt and touch the cable to its terminal, if it spins the generator, it might be a stuck regulator, or the relay. Jim
