Posted by rustred on May 07, 2012 at 21:57:30 from (72.172.100.113):
In Reply to: w9 carb adjustment posted by Justin in mt on May 07, 2012 at 19:02:30:
here is a start..first thing to do is adjust the valves. .017 hot. check the points, dist..020 mag is .013. check cap for cracks. check the wires. check the plugs. .025. check the timing. all ihc engines use the same ignition stuff. carb wont make an engine backfire. adjust the main load to 3-4 turns out. idle mixture to 1 1/2 -2 turns out.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
