Re: w9 carb adjustment
Posted by Bob M on May 08, 2012 at 06:46:12 from (74.67.189.51):
In Reply to: Re: w9 carb adjustment posted by Justin in mt on May 07, 2012 at 20:04:28:
Your M cap and rotor will swap in perfectly.
Highly recommend also:
1 - Install new plugs - Champion D21, or your preferred brand's heat range equivalent.
2 - Check/adjust the timing. Should be 0 deg (TDC) at slow idle.
