Re: 1086 'jumping'
Posted by mkirsch on May 08, 2012 at 11:59:58 from (64.80.110.75):
In Reply to: 1086 'jumping' posted by driller on May 08, 2012 at 08:58:53:
No, you don't, and you were foolish to not use it.
In fact it probably would've lasted longer had you run in TA about 50% of the time. That would have spread the load out across the two sides of the TA.
