Re: Pistons???
Posted by Andrew Z on May 08, 2012 at 15:31:53 from (64.252.115.167):
In Reply to: Pistons??? posted by MF165Farmer on May 08, 2012 at 14:31:40:
fire-crater, stepped, or dome head pistons compared to a flat piston are going to give you a higher compression ratio, thus more power. If your rebuilding you H you want to put in a set of dome pistons. They sell a set on this site that is just that, around 300 or so for a set. Whichever piston you decide to go with make sure it has some kind of dome on it, no real reason not to.
Andrew
