Re: farmall a1
Posted by gene bender on May 08, 2012 at 17:27:03 from (67.55.226.143):
In Reply to: farmall a1 posted by 2poptractor on May 08, 2012 at 06:00:49:
All depends on just where the noise you say rear end they had a noise when new due to straight cut gears. I would replace the lube in the pans with 150 and then see what kind of noise could be a bad bearing on the axle or the one at the end of the diff shaft does the wheel havea wobble and can you wiggle it when jacked up. My self i wouldnt worry about it just too much.
