Re: Me and My BIG Mouth!
Posted by The tractor vet on May 08, 2012 at 17:32:32 from (76.212.225.27):
In Reply to: Me and My BIG Mouth! posted by Allan In NE on May 08, 2012 at 16:32:30:
Easy , Allen pull the plug that looks like a pipe plug then pull the timing cover on the fly wheel housing and put the timing pointer back in the hole put the two 1/4 inch bolts back in , Now with out me running back out to the truck this evening and getting my book out to be correct on the timing set the flywheel timing marks to factory spec. then look in the hole to see if you are lined up on the marks on the gear and pointer in the little hole . Sometimes they are hard to see and if ya don't see nothing roll the engine over tilll the timing marks come up again and look again. Once ya find the timing marks pull the lines , linkage and then remove the pump.
