Re: in a pinch
Posted by mkirsch on May 08, 2012 at 18:06:21 from (67.253.161.186):
In Reply to: in a pinch posted by jake a on May 08, 2012 at 06:24:30:
If the field windings are good on the 400 starter, you could just take the armature and brushes out of the M starter and transplant them.
Swapping the nose cone is a precision welding job. Not for the faint of heart.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
