Re: 400 cyclo planter used parts
Posted by j hikemper on May 08, 2012 at 18:53:57 from (50.102.89.234):
In Reply to: Re: 400 cyclo planter used parts posted by Rootsy on May 08, 2012 at 07:06:46:
popcorn seed drum ? What if you took the 144 hole seed drum ,, ran duct tape across the holes in the same sequence as the corn drum ,,.. just a thought
