Re: Light Problems
Posted by Tony on SD on May 08, 2012 at 19:32:32 from (216.106.218.209):
In Reply to: Light Problems posted by WI-Ed on May 08, 2012 at 19:16:51:
You need to get a VOM (volt ohm meter) so you can measure the voltage from the battery to the switch to the lights and see where it stops. Also you can use the Ohm meter to check the switch
